Old 04-22-2013, 10:50 AM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
I do run newly overhauled engines with both pumps. The HV pump will produce more pressure. The bypass is set so high (100 psi) that it not reached with either pump.
In my last '66 GT350, with a new overhaul to minimum stock clearances, the std pump had 50 psi of hot oil pressure. The HV pump had 72 psi.
Z.
'65 K code Mustang
'66 Galaxie 500
