Old 04-25-2013, 12:37 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by tcrist View Post
Use this JEGS Performance Products 100732 JEGS Brake Line Fitting Adapters with copper washersabove and below the banjo fitting. See this picture and the caption below it. Front And Rear Disc Brakes Banjo Bolts Photo 18
Now I dont know anything about a jag rearend brake setup. Just thinking outloud.
Thanks, Terry. I guess it'll work just fine assuming the brake lines are drilled and tapped into a machined area on the caliper. I have to take a look. I'm thinking that the area on the caliper where the brake line enters the caliper was not machined flat on a large enough area for the copper banjo fitting to have a face to seal to, but that's going by long ago memory. I have to get over there to take a look. Thanks again,, your idea is certainly appreciated!
