Old 04-26-2013, 01:51 PM
65BD427r 65BD427r is offline
Cobra Make, Engine: Backdraft Racing #366
Default loosing electrical..
Been at it for about 6 hours now, have ran pretty much all my options! At this time i have juice to my starter and now to my ignition switch (I've replaced my ignition switch, which only has two wires running to it, 1) One to the battery, 2) One to the ignition)...no ground wire on ignition, don't recall it having one! as soon as i turn the key on, i loose power to the the ignition switch, I probed to see if i had power to other items under the dash that are a constant hot which shows hot, until i turn the key to on position and i loose power to them also! I checked the fuses and fuse relays (starter...etc) and switched the around, made no difference! The only thing i can come up with is a possible grounding issue! I have checked the main engine ground next t the starter, looks good and other grounds, supposedly one next to the floorboard under the fuse box, but haven't found it yet! this is pretty strange, any help appreciated...
