Old 04-27-2013, 12:08 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
I have noticed that if you cover up the scoop and don't force air onto the Webers the unevenness on steady gas goes away. Apparently there is too much turbulence over the Weber stacks. Webers have to draw air , not have it forced onto them.
I did that to my car and it worked.
Now, after fitting a wider scoop to make more space for the Weber stacks I did not cover up the new scoop and have that hesitation or miss or unevenness in the response on steady throttle again.
Nothing sounds better than a Cobra in a Tunnel !
