Old 04-28-2013, 11:56 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Any sweet smell in the trunk after driving the car?
Is the battery warm or hot to the touch?
Can you reproduce the fluid bubbling out of the top if you remove the battery and put it on a charger on your bench top?
Have you tried a different battery?
You say the charging system is ok... Grounds, etc...
Be minefull thart that the liquid is acid and Hydrogen is involved if you are off-gassing the battery. Wear safety glasses when working with the battery.
Is your blinker fluid level ok?
SPFWiringDiagrams@Comcast.net
