Thread: 427 heads
Old 04-30-2013, 08:55 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Thick gaskets will lower your compression, but by such a small amount that it's really not worth it. Especially - as said above - when you kill your quench area.
Instead, you should consider changing your cam timing. Hold your intake valve open just a little bit longer and lower your dynamic/effective compression.
Dynamic CR
Interactive JavaScript to Calculate Engine's Compression Ratio (CR)
http://www.kb-silvolite.com/calc.php?action=comp2
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
