Old 05-01-2013, 07:39 AM
Racer_X Racer_X is offline
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
As I recall, to be able to get the shafts out the gear set has to be removed as MDRoss1 guessed above. You "might" be able to slide the shaft back into the case far enough to use a small shepherds hook to remove and reinstall a new o-ring, but you run the risk of nicking it.
