Old 05-02-2013, 03:21 AM
dhs.buckley's Avatar
dhs.buckley dhs.buckley is offline
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Originally Posted by Chris L View Post
David can you do me a favour. I'm in the process of a new engine going in and I'm not anywhere near the car at present and wont be for a while. The new engine has a 'fast' 4 barrel throttle body going on it and I'm wanting to get an air filter from summit that actually is oval and also pulls air through the top. Before dropping a few hundred can you do a measurement for me please ?.
From the centre of your carby how much room do you have before the firewall becomes an issue ?. I'm in the process of seeing what dizzy has come with all the other parts, I have left all the spec decisions with my engine builder, I just gave him a figure and I trust him totally.
Thanks in advance
Chris L
Hi chris the center of the carb is 150mm to the bonnet rubber, 300mm to the firewall at the top and about 80mm from top of carb to the bonnet rubber, thats the same block as your current engine with an edelbrock rpm performer manifold and a holley 670
