Old 05-03-2013, 08:28 PM
Legless's Avatar
Legless Legless is offline
Cobra Make, Engine: DRB 302 Ford HO Block
I'll second Ricks thoughts, if you haven't bench bled the MC, pull the master cylinder out and bench bleed it. I put a new master cylinder in without bench bleeding it once, bled it and bled it, then drove it 1500km, went to a race meeting bled it in the car again then went to another race, still had the same issue. I ended up pulling The MC out and bench bleeding it! Problem went away. If you did have the booster connected you'd probably find the brake peddle heading for the floor.
