Old 05-04-2013, 01:00 AM
sevenohms sevenohms is offline
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Originally Posted by renovationinnov View Post
tried leaving it over night with the front up on stands
3 bottles of fluid thru now & still soft '
then tried the master cylinder bleed reconnected the lines & rebleed still the same
but did notice as my misses release the pedal till shot brake fluid up in the master cylinder
might ring grilock Monday & see if they have a idea
master cylinder is new xe falcon white fluid resevior all new lines & jag reconditioned calapers
depending on your installation the caliper might not be able to bleed all the air out. I'd do what sideshow suggested, clamp the hoses on the front, and see if they improve, then I'd take the caliper off and put the bleed nipple to the highest point possible and see if that helps. just make sure you put something between the pads
