Old 05-04-2013, 04:35 AM
strictlypersonl strictlypersonl is offline
The system is acting as if the alternator field terminal has a constant 12 volts. That voltage should normally be reduced by the regulator so that the alternator output is 13.8-14.5V. Not what you have...
Also check that the V-R is properly grounded. If it can't tell what's zero potential, it might do some strange things.
