Old 05-04-2013, 05:59 PM
PLDRIVE PLDRIVE is offline
Cobra Make, Engine: Backdraft, SBF 351w (463 CI)
Whats your car no? When was the last time clutch fluid was changed? Do u have a heat shield under the clutch master? I would suggest u tighten the linkage up, replace fluid if it has not been changed lately, and order a heat shield from BDR if it does not have one.
Open the Bleeder on the slave (drain oil). Add fluid and flush till fluid is CLEAR.
Bleed until clutch is firm. My have to bleed a few times.
Fluid Motul RBF 600 (most motorcycle shops will carry it.)
