Old 05-04-2013, 06:19 PM
D111 D111 is offline
Cobra Make, Engine: 427
Originally Posted by PLDRIVE View Post
Whats your car no? When was the last time clutch fluid was changed? Do u have a heat shield under the clutch master? I would suggest u tighten the linkage up, replace fluid if it has not been changed lately, and order a heat shield from BDR if it does not have one.
Open the Bleeder on the slave (drain oil). Add fluid and flush till fluid is CLEAR.
Bleed until clutch is firm. My have to bleed a few times.
Fluid Motul RBF 600 (most motorcycle shops will carry it.)
Do you know if you have to push The lid down before turning I am afraid to force it it does not want to open?
