Old 05-05-2013, 12:38 AM
boxhead's Avatar
boxhead boxhead is offline
Rob, put a picture up of your calipers fitted to the car, also make sure we know the orientation (which way is up)
Sounds like you may have them fitted left to right and vice versa.
Also, note to all, never, repeat NEVER use vice grips on your flex hoses.
You WILL damage the rubber if not external then internal, only way you will find out is when you jam your foot on the brakes and the hose ruptures.
If you need to clamp off a flex hose, spend teh $12 and buy the proper tool from supercheap (no sharp edges and not ratcheting so you can over squeeze them).
Cruising in 5th
