Old 05-05-2013, 04:38 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
your displacements are incorrect...... Your problem is what you first suggested.... if you don't have a dual master cylinder setup eg one for front one for rear with a balance bar and you are relying on a single master cylinder your displacements are wrong eg your rears are locking up because your master cylinder has supplied more fluid to the rear than the front..... you need to fit a proportioning valve to bleed off pressure to the rears.... or reduce the piston size of the calipers on the front..... or increase the piston size of the calipers on the rear
