Old 05-05-2013, 04:47 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Best way I have found to bleed a system is simple....just use a big syringe first put it in your master cylinder an suck it dry... then put a bit of clear plastic hose on the front and push it fast back through the bleeder.... go to slow and the air will remain in the high spots....using the pedal to bleed wont clear the air out of the high points in the brake lines
