Old 05-05-2013, 03:08 PM
Legless's Avatar
Legless Legless is offline
Cobra Make, Engine: DRB 302 Ford HO Block
Originally Posted by AC-460 View Post
Best way I have found to bleed a system is simple....just use a big syringe first put it in your master cylinder an suck it dry... then put a bit of clear plastic hose on the front and push it fast back through the bleeder.... go to slow and the air will remain in the high spots....using the pedal to bleed wont clear the air out of the high points in the brake lines
If the master cylinder is in situ wouldn't it still be possible to have air in it if the piston wasn't fully compressed where as with a bench bleed you can be sure the piston is fully compressed?
