Thread: Weight
Old 05-07-2013, 08:14 PM
ERA2076 ERA2076 is offline
Cobra Make, Engine: ERA - B2Motorsports Dart 331
Default Weight
I've been weighing stuff as we work on things
351w w Lakewood & clutch 520 lb
Lakewood Bell Housing w plate 39 lb
Clutch Pressure PL 19 lb
Flywheel 24 lb
Spec aluminum flywheel 11.1 lb
Spec Pressure Plate 13.41 lb
Spec Clutch Disk 3.9 lb
Tremec 3550 w lube 107 lb
Performer Heads
Performer RPM Manifold 17 lb
Redline Weber Manifold 17 lb
Weber 48 IDA w manifold 40 lb
Header 5.4 lb ea
Oil Cooler
Timing Cover 3.1 lb
Aviad Oil Pan w pickup 16.2 lb
Aluminum radiator w fan 22.25 lb
Edlebrock mechanical fuel pump 1.9 lb
Kirke Aluminum seat - bracket - cover 14.5 lb
ERA Seat w slide 31 lb
EAR Set w/o slide 15.5 lb
Carpet Set 7.5 lb
Windshield w frame 25 lb
Full comp screen
Lexan replacement screen
Aluminum Cobra Cast Covers 5 lb ea
Aluminum Spacers 3 lb ea
Trick Flow Fabricated VC 2.2 ea
Canton Fabricated VC 3.1 ea
Avon 225x65 26.75 lb
Dunlop 235/60 on Trigo 45.8 lb
Avon 225/65 on Trigo 46.5 lb
Spax Shock 3.5 lb ea
Eibach Spring 4.4 lb ea
Front Spindle w Rotor 35.25 lb
Front Spindle w adapter 13.2 lb
Lower Control Arm 4 8 lb
Upper Control Arm 2.65 lb
SPC adjustable UCA
Subaru Steering Rack 11.8 lb
Willwood Superlite w pads 6.9 lb ea
Rotor 11.7 lb ea
Hub & hat 10 lb ea
Front un-sprung weight 102 lb - can we do anything here?
Missing a few I have not weighed yet
