Old 05-12-2013, 04:55 AM
patrickt patrickt is offline
Post your current build specs.
Stroke - 4.125 (SCAT crank)
Bore - 4.155
447 CID
Wiseco Flat Top Forged Aluminum Pistons - 10.6:1 Compression
Edelbrock 76cc Heads polished and port matched to a Blue Thunder dual plane Intake Manifold
Erson Roller Rockers
Holley 4160 750 CFM Vacuum Secondary Carb
Elgin SFT Cam 324/324 Advertised Duration
245/245 at .050
.535 lift, less .024 hot lash, for an effective lift of .511
114 Lobe Separation Angle, ICL installed five degrees advanced at 109
Aluminum water pump and flywheel, Canton RR Pan w/ HV Pump
ROMAC aluminum/steel balancer
