Old 05-12-2013, 11:08 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Orrrrrrrrrrrr------------------
You might want to look at a combo that the Nascar boys did back then----427 so block, 352 crank for 390/396 cubes------the aluminum heads re worked and you'd save probably 100 lbs over what they were running with the alum h2o pump and alum clutch------
