Old 05-18-2013, 03:09 AM
Modena's Avatar
Modena Modena is offline
On important fasteners (eg brakes and suspension) you should check with the OEM (Holden in this case) for the specs of the fastener. I have bought quite a few new fasteners from Holden during my build. You will find that many of the type of fastener you have pictured are in fact designed as single use items. This is not marketing to get you to buy a new one, rather when you have a new one you can see why - the nut will thread on by hand only about half way before stopping. Torquing with tools then stretches/gives in the bolt and the nut and it torques up tight to spec, but will not fasten the same a second time. Someitmes it is just the nut which is single use, and sometimes the bolt and nut. Check the workshop manual to be sure.
Otherwise, I replace with grade 8+ bolt, washers and nylocs.
Ben in AU
