Old 05-20-2013, 03:32 PM
Double Venom's Avatar
Double Venom Double Venom is offline
SGR,
FWIW, almost all firewalls from day one are contoured forward. (Yep, they should be 90's but as a result from pulling them from the mold to soon, this is the results. Simply get the firewall mounted to the floor and force the top of it in place.
ALSO: A problem in the making.... your brake line at this point should not be on top of the frame, the floor tunnel needs to be mounted flush to the frame upon final fitting. Their is plenty of room to mount the line on the side of the E-Brake support, still allowing the tunnel to fit into place.
Where are you in Ohio if I may ask? Want a visitor for a day? Might be able to get there for a few hours if you want??????
DV
