just wondering if i should run a seperate cable from the battery to run the accessery side or run from the starter motor
next what use do i run from this to the fuse box to the ignition switch
do i need to fuse accessory & on with a self reset fuse to each before i run to a fuse box
is it better to fit relays to both low & hi beam as i was going so both where working for more light on hi beam
thanks ROB
