Old 05-22-2013, 05:23 PM
Silversmith Silversmith is offline
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Thumbs up
Rpatton3
Go to "RPIdesigns.com" item# C6PRLF Enter the item # in the keyword box & you will see what I put on my AC. I simply moved/raised the oil cooler up 2" & fit the remote control retractable front plate holder under the oil cooler to fit into the oil cooler opening. While the oil cooler now splits the two openings it has no effect on cooling. In fact By raising/fliping the plate up during colder weather the plate actually provides some extra wind blockage to the cooler. the plate is easy to install, I used the same bolts from the original cooler & a 2"W x 1/8"T x 1'L strip piece of alum. from Home cheepo & bent/fabracated the 2 brackets to raise the oil cooler for the proper clearence req. to fit the bracket. You will see a video when you look @ the parts from rpi. It works the Balls People get a kick out of seeing it work @ shows too! PS: it cost $140 bucks
