Old 05-24-2013, 07:38 PM
Mark Brye's Avatar
Mark Brye Mark Brye is offline
Cobra Make, Engine: BDR354/FMS392
Thanks for the pictures. Now I have an idea of what I need to do. I have had an oil cooler for a while that I have not mounted. I think I will install the oil cooler and then use those cooler mounting bolts for the lower radiator support bracket. I think I will run the bracket under the cooler and not under the car so it will be seen less.
Is there any room to mount the radiator higher in the car if I change the upper mounting hole locations from stock?
