Old 05-28-2013, 08:42 AM
DAVID GAGNARD's Avatar
The engine was built in 2000 and has probably seen 8,000 track miles since then, so we were thinking we'd rebuild this winter anyway. Guess it will be sooner than that.
Don't know what kind of rpms you'll turn with the engine or what rpm you usually shift at, nor what kind of maintenance you do on the engine or how hard you'll beat on it, but I will say after 8,000 track miles,you got your moneys worth out of it..........
and without knowing what all is damaged,it could be as little as the crankshaft or the whole bottom end........
David
DAVID GAGNARD
