  #21 (permalink)
Old 05-29-2013, 11:27 PM
sideshow sideshow is offline
Neutral
bad earths are common when u fit battery in boot and u use the seat mount bracket for an earth as this bolts thru body to chassis but with so much fiberglass inbetween ive had some cars get bad earths
or your starter is stuffed
or your main power cable to starter has bad connection
did u crimp properly with proper tool or did u use a vice and crimp lug on end
or did u solder which is the worst way to attach a lug to starter cable
also make sure u use 2b&s cable or lug size 35 cable
my website
www.sideshowsperformancewiring.com.au
