Old 05-31-2013, 02:54 PM
DAVID GAGNARD's Avatar
Originally Posted by dcdoug View Post
I thought that was the case, but went through the warranty and I'm not sure it's voided for HPDE events vs racing (which does void it). Anyone have the answer to this?
Here's a link to their warranty info: http://www.fordracingparts.com/annou...ent_2012v2.pdf
I went thru the warranty list and could find any number of reasons they could/would void your warranty for track use........
lets say it burns up on the track, all they have to say was it was an oil starvation problem and you had the wrong oil pan on it for it's intended use....how are you going to prove you had good oil pressure things went south?????
There are a hundred things they could/would come up with to void the warranty......
BTW: I have one of those expensive BOSS 302 blocks, serial number under 1000.....guess what, the rear main seal area was machined wrong,it's .050 out of wack, it doesn't leak oil out the back, it pours oil out the back.....
Had to tear down the engine to the bare block,crate it up, send it to Michigan for them to inspect it and tell me there was nothing wrong with it and that it shouldn't leak a drop.........well, it leaks like crazy and had it checked by 2 different machine shops and they both came up with the same thing, bad machining where the one-piece rear main seal goes,not centered in the block.....
So now I own a nice pretty $1,700.00+ paperweight!!!!!!!!!!!!!!!
THANK YOU FORD RACING!!!!!!!!!!!!!!!!!!
BTW: when I called the tech people about this, first question was is it the big bore block (4.125) or the standard bore block (4.00)????
tech let it slip they were having major problems with the first big bore blocks and were taking them back with no questions asked....I hope they have that problem fixed by now.........
David
DAVID GAGNARD
