Old 06-01-2013, 03:27 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by jhv48 View Post
Before you start messing with colder/warmer plugs, determine whether the plugs are oil fouled or fuel fouled.
Different solutions to each of these. Plugs will appear black and could be damp and smell like gas if fuel fouled. Black and oily will be more problematic to solve.
Correct.
Do not try to correct the condition you have with a hotter heat range spark plug.
For a street car, one range colder than factory spec is generally enough.
What camshaft specs have you got?
Give the idle air bleeds a shot of carb cleaner first and reassess.
http://members.tccoa.com/392bird/airbleeds.jpg
Gary
