Old 06-04-2013, 04:02 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by Gaz64 View Post
Have you taken the carb throttle body off for a look?
I'm thinking the added holes are something to do with creating an "air seal" with the throttle shafts.
In this case there would be intersecting holes going down to each throttle shaft.
It runs all the way through from outside to inside the venturi and comes out in the center above the butterflies. It's separate and above the throttle shaft. There is one for each venturi.
The air seal is sort of an interesting idea, but hard to know how well that woud work.
Mickmate thought they might be something to do with the casting process, but I don't know why they'd go all the way through in that case.
Someone here has to know the answer.
www.partskeeper.com
