Old 06-04-2013, 07:38 AM
1985 CCX's Avatar
1985 CCX 1985 CCX is offline
Finally drilled body to accept the Enots cap for fuel addition. This starts the process of fuel lines for the start up.
I think it is good as the trans will hit the crossmember if I lower it another 1/2", wanted a little bit of play. Rubber mount may also settle a bit. I am very close to the tailshaft height when compared to 2136. Should be fine.... Thanks for question.
Vintage bowmalloy hardware was from Kevin Ahern. Thanks!
