Old 06-06-2013, 03:12 PM
Silversmith Silversmith is offline
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
Ted, if yo want BB power I would strongly suggest the 385 series engines. A 429 or 460 cid Ford. you can easly get 650 to 700+ hp for $12K or less; max rpm to 6,500 & all the Rush you would ever want. Parts are plentiful & cheap. Ok cheaper than FE builds I think I saw a couple of
AC's with 460's in the add section with CA. 100 cert's Take you time & look @ "Cobra Country want adds also. Many spf are SB's wich are fine also & many for less than 50K. & some ERA's as well. Good luck m8. If you are interested in a 460 engine build sheet just let us know!
