Thread: Ignition
Old 06-08-2013, 08:16 AM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Don't know what box you have, but an MSD 6al has 2 power inputs, one from the ignition ckt, and one direct from batt. Could be component failure in box. Disconnect batt cables, measure resistance from positive cable to ground. should be "open", infinite res. If not, disconnect box main power wire (should be fused, remove fuse) and ck again. If res is now infinite, you've identified the culprit !
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
