Thread: Ignition
Old 06-08-2013, 07:28 AM
littlewave littlewave is offline
Cobra Make, Engine: #6101 streetbeast Ingelese stack EFI 351w/t-5 9" 4link 3.55
Originally Posted by MOTORHEAD View Post
Don't know what box you have, but an MSD 6al has 2 power inputs, one from the ignition ckt, and one direct from batt. Could be component failure in box. Disconnect batt cables, measure resistance from positive cable to ground. should be "open", infinite res. If not, disconnect box main power wire (should be fused, remove fuse) and ck again. If res is now infinite, you've identified the culprit !
It is a Pertronix Second strike, and thanks I will check that out.
