Old 06-10-2013, 06:13 AM
jolsen42's Avatar
jolsen42 jolsen42 is offline
Originally Posted by fordracing65 View Post
Where did you get your fuel log from, for the carbs???
I butchered an old 3-2 fuel log that I had. Cut off the backleg and fuel fittings for the middle and back carbs, plugged and tapped for a 45 degree brass fitting for the rear. Also had to remove and reposition the fuel log leg to line up the inlet and outlet for the front carb. I'm fairly pleased and it looks pretty much like the original Carter fuel log.
jjo42
