Old 06-14-2013, 01:38 AM
FatBoy's Avatar
FatBoy FatBoy is offline
Cobra Make, Engine: Kirkham #523, 427 S/O
Originally Posted by CHANMADD View Post
How are you going to bleed brake , if the line faces down bubbles go to the top. The Watts link does not replace the radius arm without a radius arm you will get shudder at the wheel still. The Watts keeps the wheel from collapsing if you break a drive shaft .
The suggestion is to split the calipers and keep the bleed nipples on the top. Pay attention.
The Watts linkage doesn't "keep the wheel from collapsing if you break a drive shaft". It stops the suspension twisting under heavy loads e.g. hard acceleration and braking. However, I broke so many fulcrum bolts on mine that I gave up and took it off.
Paul
