Old 06-17-2013, 02:34 AM
renovationinnov's Avatar
renovationinnov renovationinnov is offline
Cobra Make, Engine: venom motorsports /ls1 auto
slowly
had a silmlar problem with a dellows kit
I found that you could slide the throw out bearing by hand easlier by when the clutch fork was attached it would bind on the input shaft
so I found I had I had to machine the input shaft 1thou for clearance that what dellows advised & it worked
hope this helps ...ps ring dellows & see I they have had this trouble before
good luck rob
not all your babies are your children
