Old 06-18-2013, 07:45 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Carmine,
followed your tip on the idle jet when going with a pump bypass and it works. Will have see if the .50 bypass will do without a bog or if it needs a larger idle jet. Larger idle jet makes low speed action smoother and A/F meter does not show richer than before, rather leaner.
Nothing sounds better than a Cobra in a Tunnel !
