Old 06-20-2013, 08:01 AM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Neutral
Originally Posted by vatdevil View Post
A bias tire has stiffer sidewalls which provide a harder ride, transmitt more vibrations, and less tire contact with the road when cornering. Bias tires do offer more warning at traction limit, require less negative camber, and give more feedback. They operate at higher slip angles, which can make them feel sloppy on entering corners. Radial tires tend to follow wheeltracks while bias tires will try to climb out (wandering). Bias tires arent bad but different than radials. Good racing radials are closer to bias design than radial(stiffer sidewalls). But ANYTHING is better than the crap BFGs you had.
Glad you are liking them and glad you are no longer wearing BFG's. It is an amazing difference. Did you have the car corner-balanced? Next to tires, that can also make a huge difference. At least it did for me.
