Old 06-28-2013, 01:56 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Slowy
Take your pedal off and drill a hole up 10mm...... this will increase the leverage and make the pedal lighter..... you may need to increase the length of the push rod to get full stroke out of the master..... make sure the piston comes all the way back in the master.... use a syringe to back force bleed....use the syringe and suck the master almost dry .....then force that syringe full with a piece of clear hose back through the bleeder on the slave ....force it through quickly to force air out of high spots
