Old 07-04-2013, 05:23 AM
stephen low's Avatar
stephen low stephen low is offline
The G Force and the RMC chassis were built to simply receive the standard Jag donor suspension parts.
If you are building a special you would need to replicate the same using Jag gear or the same using some other donor I guess.
You could use some of those fancy fully adjustable upper and lower arm sets that are coming out of the States but again the mounting locations would need to be carefully considered and located I guess.
One reason why I was happy for a kit that has had this work already done.
Steve
slowy
