  #36 (permalink)
Old 07-04-2013, 03:08 PM
David Hodgson's Avatar
David Hodgson David Hodgson is offline
Originally Posted by dhs.buckley View Post
Love the look of the 15" wheels, what do you call wide wheels? My python has 15" x 10" 305mm wide tyres, is that wide or where originals wider?
It's not so much the width Dave is referring to but the 'dish' or offset of the rear wheel. The earlier CR's were wider from flange to flange in the rear end allowing only a shallow dished rim to be fitted under the original guard.
Back on topic, depends on your skill level, your contacts and the challenge you want, any kit is do-able, though the previously mentioned kits would be a sensible idea.
SLIPRY
Last edited by David Hodgson; 07-04-2013 at 03:13 PM.. Reason: Doh - forgot a bit of text.
