Old 07-06-2013, 08:45 AM
Wisconsin_Snake Wisconsin_Snake is offline
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Default Desperately nee help with the engine harness
Ok, I am using the early CR wiring harness and need help modifying the Engine Harness part of it. (I have the Ford Engine Harness referred to in the manual).
I am installing a Fuel Injected engine that has it's own engine harness.
What I need to know is what can I eliminate on the CR engine harness.
  • The alternator I am using has an internal regulator.
  • I am guessing I do not need the ballister resistor
  • The EFI harness has it's own coil/fan (it's the Ford 5.0 Ron Francis harness) if that helps.
  • I plan to use the oil water gauges using the CF harness.
Please help as this is boggling my mind.
I have the pages in the manual detailing the engine harness converted to pdf.. I just don't know where to host them.
