Old 07-07-2013, 07:25 AM
stephen low's Avatar
stephen low stephen low is offline
As said this was an early picture and there is now a rose joint bolt at the end of the clutch push rod and attached at that pedal attachment hole.
I'll measure the 3/4 master to see what the maximum stroke is for this rod. Would it be safe to assume the 3/4 and 5/8 masters have the same stroke but just different bore sizes? Don't think they are from the same manufacturer though.
If I was forced into this option it will be a messy correction at the front of the painted footbox , that's all.
slowy
