Old 07-08-2013, 12:54 PM
55312's Avatar
55312 55312 is offline
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
Do you need to pull the transmission? In my case, I didn't need to pull it (a top loader) so I split the engine at the bell housing and had at it. Really went very smoothly and putting it back in was no problem. Alignment was not an issue as long as you install the clutch and pressure plate properly. Also....some beers and a friend or two makes it go so much easier.
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
