Old 03-18-2002, 10:39 PM
Whaler Whaler is offline
Default goodies arrived from Enzo's -2 questions
Boy It feels like christmas when you see that finishline parcel show up.
I ordered the turkeypan, complete shifter and goodies to go along with that. Mirrors, badges. Can't buy all the goodies at once.
Had to do a little opening up of existing holes for the fuel inlets on the dual feed. I do have a slight clearance problem on one end with a small pump arm on the bottom side. I have opened up a small slot to allow the arm to move up and down...
Q)will using a thicker gasket under the carb bring me up enough off the pan bottom for a little more clearance?? Using an holley 850 mechanical sec. with manual choke (double pumper)
Turkey pan is definitely a nice looking unit as was the shifter.
Q)Also which side of my tko stub should the handle be bolted to?? close to me or away from me?
Tim
