Old 07-10-2013, 10:29 PM
lippy lippy is offline
Default Fuel line routing and filter/regulator locations
I decided to use the RobbMc 1100 HP mechanical pump, Aeromotive Platinum polished deadhead regulator and 40/100 micron filters, and probably Fragola or Aeroquip teflon/stainless braided lines. In the engine bay, the fuel lines will go from the pump to the 40 micron filter to the regulator, and then I will have two lines exiting the regulator and connecting one to each bowl of the carb, with no log. So my questions are: (1) where are the best locations to mount the regulator and 40 micron filter, and (2) how should I run the hoses in the engine bay so they look neat? Thanks.
