Old 07-11-2013, 10:57 AM
lippy lippy is offline
Originally Posted by LodiWino View Post
Lippy;
I went through the same fuel pump location question and ended up mounting the pump, filters and regulator on the aluminum panel above the gas tank.
There is enough stuff already in the engine bay without adding to the cluter with a big fuel pump and associated plumbing...
The pump is driven by and mounted on the engine. The regulator and filter need to be near the pump and carb, so aside from the 100 micron tank filter, the rest needs to go in the bay..
