Old 07-11-2013, 01:49 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Unless the owner has installed a hidden kill switch(s) or something, you pretty much get in, pump the gas pedal once or twice (carbureted engine) and turn the key. If a push button starter was installed you insert the key and turn to position #1, pump the pedal and push the button. Perhaps he is referring to an engine without a automatic choke, in which case you keep it running for a min or two with the gas pedal....
Or maybe you turn the key and need to pray it starts?
I can't wait to hear what you needed to do to start it.....
SPFWiringDiagrams@Comcast.net
