Old 07-16-2013, 06:00 AM
Shootnride's Avatar
Shootnride Shootnride is offline
Cobra Make, Engine: Superformance, 427SO
Originally Posted by GEORGE ANDERSON View Post
You should have about .0005" to .001 Press with Anti seize compound. Some dampners like BHJ you can buy on the small size and then fit to the snout.
George
George,
Thanks for the reply. I found that the bore on the balancer was a lot worse than I first thought but the crank snout is in pretty good shape. Since this balancer was already balanced for my engine I decided to repair it. I bored it, machined a bushing with a flange on the outboard side from 4140PH, installed it in the balancer with a .0015 heat shrink fit, drilled and tapped through the flange with three 1/4-20 set screws just for some extra security and broached the key in exactly the same orientation as the original. I bored the bushing for a .0005 press fit but haven't installed it yet. Hopefully all will be ok now.
Ted
